24bit/96hz for Dummies - Questions I Didn't See Answer for Throughout the Web
Oct 19, 2013 at 11:37 AM Thread Starter Post #1 of 7
KBGolfRunner
I'm new to the Head-Fi Community and have recently bought an entry-level setup - Garage1217 Project Starlight, NuForce uDac 2, ZMF Modified Fostex's with XLR input.  I have my old CD's downloaded to a 2 TB Western Digital My Passport for Mac in Apple Lossless format, and I have MacBook Pro Retina.
Here are my questions and thanks SO MUCH for your help.  Please answer one, two, or all of them.
Does playing music through my External Hard Drive make a difference?  (I could move music to my SSD Hard Drive, but it's only 256 Gigs)
Should I put the Audio MIDI Setup on 24bit/96hz even though I'm playing 16bit/44.1hz?  I have one 24bit/44.1hz and one 24/96 from HD Tracks?
I find the music separates better and is cleaner on the 24/96hz, but the 16/44 for my Apple Lossless songs (16/44.1)
Is DAC Burn In Time really true?
Will my system sound better if I get a Audioengine D1 with Optical Input and run an Optical Out from my computer?
When I'm downloading an album from HDTracks should I turn off my other applications?
I have a Audio Technica AT-LP60 Turntable.  Can I make 24bit/96hz that will sound better than my Apple Lossless on my current system?  Will I need Original Mastered Recordings?  Really dum question here - Will the slight cracking sound on my older albums come through as much after I record them into my computer?  I'm thinking I need to get a turntable with a USB - Is that correct?
Can I download a Music DVD in 24/96?  I have my Music DVD's on quicktime recorded through Handbrake right now?
If I get these answered I will be "complete" and will no longer be a Head-Fi Addict!!!  I doubt this is true..I have a feeling it keeps going to different levels, etc.
Thanks for reading this far,
Kevin
Oct 19, 2013 at 1:04 PM Post #2 of 7
It should make no difference whatsoever, as long as your USB/Firewire drive and connection are operating okay you should be fine, you are only using the firewire/usb to get data and not at a very challenging rate , where did you get this idea from ?
There is a 99% probability that this difference is a product of your imagination/expectation bias, I'm not being rude, we see this a lot here. Unless the software/hardware operates badly at a given rate there really should be no audible difference, certainly you are gaining zero extra audio information.
To date there is zero credible evidence to support DAC burn-in
According to the specs the D1 is rather better in terms of noise (SNR 110db, vs 91db)  whether you will be able to detect the difference is anybody's guess
No, in the unlikely event that something you are doing interferes with the download the Internet protocol stack has error correction and any lost/corrupted packets will be retransmitted until they are correctly acknowledged, unless the host site is using UDMA (very unlikely) in which case it is a crap-shoot.
There is no point in making 24/96 recordings from vinyl - the dynamic range of vinyl is at best about 75 - 80 db on pristine vinyl on a high quality TT with perfectly aligned and high quality cartridge you might just get that, trust me your TT will not manage anything anywhere remotely near that so you do not need to worry about 24 bits.
Mastering for CD and vinyl are frequently different so comparing any LP rip vs the CD rip may not be meaningful, even if the mastering is identical and assuming equally competent LP/CD mastering the LP rip cannot be superior due to the limitations of the vinyl medium
If you are serious about vinyl rips a better bet would be to get a capture device and a phono stage that outputs a line level signal. A phono stage will cost you about $110 unless you have an old Receiver/Amplifier lying around, a capture device could be anywhere from $30 (Behringer UCA222)  - $300. The USB turntables tend to be of only moderate technical quality.
Kevin
Oct 21, 2013 at 6:46 AM Post #3 of 7
Kevin
Setting it at 24 won't harm, and might technically help, depending on how you plan to use it.
I'd leave the sampling rate at 44.1, though. I fail to see how a higher rate can be of any gain.
I'd second Nick on the recommendation of a stand-alone ADC device. I've used a handheld Sony PCM recorder with good effect for similar purposes. Most modern consumer devices should do a fine job.
However, I'll disagree with him on not capturing in 24bit resolution. I'd do that, then import the files to Audacity or similar for level adjustments, EQ, ironing out the most offensive extraneous noises, divide into tracks, and then convert to 16/44.1.
Edit:
Hey, wait a sec. Why not just use the analogue in on your Mac to capture vinyl? I'm sure it would suffice dandily.
Oct 21, 2013 at 5:00 PM Post #4 of 7
I experimented with upsampling yesterday. I used several sample points from 44, 88, 96 out from foobar and on to 176 and 192 both 16 and 24 bit in the USB properties and with 44/16 ripped flac, it all sounded the same. It's common logic here that you can't improve, only pass along what you start with. The only benefit for having the capability of higher sampling is for higher resolution source material. If you're doing standard CD rips, higher resolution just takes up more drive space.
Oct 22, 2013 at 4:35 AM Post #5 of 7
I wonder whats the picture that comes up in our minds when someone says 'signal'.
In my mind, its a wave pattern, either EM or sound.
I'm pretty sure a lot of people come up with some other form in their mind. Maybe some kind of a psychic force that is captured into the recording, and needs infinite amount of power to fully materialize. The attributes they associate with signals are pretty interesting.
Oct 22, 2013 at 5:59 AM Post #6 of 7
duuut duuut, duuut duuut duuut, dut duuut dut, dut dut dut, dut.
Oct 22, 2013 at 11:05 AM Post #7 of 7
When we talk about digital audio / signal processing: samples. Attributes: discrete time, quantized
Yeah, an actual (simple) signal would be a sine wave.
