infinitesymphony
- May 15, 2006
I used Cubase to record a few files at 24-bit/88.2 kHz and then bounced them down to a stereo WAV. This WAV file won't play in Windows Media Player but will play in Foobar. However, when I convert it to FLAC, it won't play in anything.
When I encode the file with flac.exe, it gives the warning, "WARNING: legacy WAVE file has type 1 but bits-per-sample=24," but it finishes and verifies. Foobar won't play the FLAC at all.
Here's the strange thing... Both WAV and FLAC work if I downmix the file to 16-bit/44.1 kHz (but FLAC still gives the same warning), and WAV works at 32-bit/88.2 kHz. I don't understand why 24-bit/88.2 kHz is such a problem.
Other people have encoded at that rate without issue, so I'm not sure... I've also tried the --lax command-line option without success.
