Jimster480
I see my last post never posted, I guess some glitches with the new forum software.
I will start testing it probably today.
Where's the bass?Have been testing the M8A, so far I don't sound much of a difference between it and the D30.
It has the filters and so far I have only used fast and my RP-HD10's.
I'll test with the quad drivers tomorrow with some difficult jazz/classical songs.
Right now I am testing it with R&B, Rap, GoaPsy
Additionally the additional "heft" comes from a giant heatsync they built into the chassis in the M8A. Maybe it is to increase its lifetime as some people have complained of early failures on the M8 from overuse (it does get super hot and so far the M8A is cool to the touch).
What do you mean by that specifically?Where's the bass?
The sound I care about is classical and jazz which also make great test material.What do you mean by that specifically?
So far the M8A is beautifully accurate & detailed and the filters just like one the M8 change the sound just a bit depending. Mini is the least obtrusive filter, but the unit stays mostly cool to the touch even now that its been left on for days.
I haven't tested it against the M8 yet but it is a bit smoother sounding than the D30 and maybe a tad bit brighter. Depending on the kind of music you listen to you might prefer the sound a bit over the D30 which has obviously a very flat sound.
I will be listening to it some more tonight especially with the quad drivers and some more intricate tracks where there is more detail. Even 90s rap doesn't have that much detail save a few tracks, the bass is great but that is only one component of sound reproduction. And as you may know vocals in rap are nothing special and most mainstream players are able to reproduce most tracks fine.
Audiophiles and probably headphiles love to describe sound in tonal balance. This of course is not a great idea since all of these devices likely measure flat. My pet peeve especially if then said phile thinks you should reEQ your system (driver levels on speakers or subs etc., not so much an issue with headphones.)
I'd much rather hear about timber, texture, perceived level of blackness. Bass certainly can sound very different. My current Avatar is a placette remote volume control that uses bulk foil resistors. When I put that in my system for another volume control it was like a bomb went off. Crazy dynamics. (Friend now calls my system "massive attack" from the change.) It still measures flat and the same likely, but conventional measurements probably don't pick up what is happening with the sound.
I think the M8A is out of the running for me. The Topping will do and I've enjoyed the testing. With the Topping I don't here critical changes going from 24/96 to DSD and other things. I hear them with the D30, but they are swamped by the difference in the analog stages. These are nice DACs, but for my all tube system they aren't a great match because they take away some of my purity I'm getting with my current setup. Its a giant difference that swamps HD digital format wars. That being said I do like some rock recordings on the Topping so I'll continue to play around and I have a feeling it will be a favorite for a number of those recordings.
I'm exceptionally pleased with the purchase experience and your recommendation. The money saved is likely going to a special tweaked out version of my current player. I'm cutting everything to 24/48 or 24/96 and putting it on regular old DVDs that will play in any DVD or bluray player etc. Its old school and I'd love to change, but I'm not confident that even an Oppo tricked out would beat my current "hotrodded" player. The budget is tight so I'm staying very cheap on digital. (LPs still rule, but while funds are tight HD digital has my full attention.)
I understand what you mean, as my initial findings show I hear no difference in timbre or blackness levels with the M8A vs the D30.
Overall the M8A sounds great, but then again so does the D30. Since DSD is something that really has limited offerings in the first place and both players can play DSD files and high level PCM I don't really see the reason to splash out the extra cash for the M8A. I can say though that the longevity problems with the M8 are most likely fixed since this unit runs so cool in comparison.
When I get more time I will do more side by side comparisons and eventually I'll test the M8/M8A/D30/Modi Multibit all side by side and make observations of each.
Ah... the MassDrop ends in 11 hours !! I wish I had your thoughts in comparisons before committing to the massdrop.
I have been looking for an DAC to match with my Aune X7s amp. right now I am using two DACs
Schiit FULLA 2 : AKM AK4490 with TI OPA1662-based filter stage (My portable/work-place DAC)
Creative Sound Blaster X7: Burr-Brown PCM1794 (Home desktop DAC)
I am not really educated and just knowing the dac name and how great it is, or differences between them.
I have been thinking of getting the Modi Multibit (Mimby) but saw the M8A on MassDrop.
Dear all ,
I got a SMSL M8A . I got the driver from Shenzenaudio web side but when i try to install to my windows7 , its getting failed.
Is there anybody who can help me . It may certificate problem but i cant find a proper solution.
Will wait any reply.
Thanks
yes i runned the driver installation with admin rights. Its seems got installed but when i plug the usb again , its checking windows drievers update and trying to complate the installation but giving failed message.Is there an error message? Are you running with administrative rights?
When ii am rebooting my computure i open boot management and chose installation uncertified program forcement ... and installation has been done after that...In computer management check the event log for error messages, check the device list to see if it's there. If there uninstall (using the uninstall in C:\Program Files\SMSL\SMSL_Audio_Driver), reboot and re-install
Now i should find a correct info to adjust foobar2000 cause no sound to me amplifier at the moment ( i chose out but usb dac also but no sound for DSD )
