meatbix
- Nov 9, 2016
Dear head-fi DIY community,
I apologise if this post is in the wrong section,
I recently managed to destroy my girlfriends SE535 IEMs and am in desperate need to repair them, Hopefully a few of you could enlighten me with your technical knowledge.
Picture 1: The Damage
Applying my caveman technical skills, I figure all i need to do is to is establish an electrical connection between the three pins and the exposed copper wire, is this correct? I purchased a solder iron and was all ready to go at it but what concerns my is when I manually press on the wire I cant hear anything..
Picture 2: Unexposed underside
Additionally on the underside of the monitor there is another copper strip that is not exposed, does this need to connect with any of the pins?
Pictures: My pins
Finally, of the three pins, the first two from the top have residue of the copper connection that used to bring pleasure to my eardrums, the middle pin is rotatable 360 degrees so could connect to either of the copper wires?
Please if anyone could help me it would be greatly appreciated
God bless you all, Meatbix
Pictures: My pins
