germanium
I guess that having horn loaded speakers before myself I would have a good Idea how this type acoustic loading sounds. It is unmistakable, it's there & it sounds very nice indeed.
Note that some idiot added that to the article in its recent history. Probably the company website that is used as a reference for that section because they wanted to call their waveguide a horn, and none of the people that wrote the article to begin with picked up on that change. The first paragraph of the article quite clearly defines the purpose of a horn.
And I don't how you can "hear" to know that the waveguide is adding any significant acoustic loading. You'd have to measure the tweeter with and without the waveguide to determine if that's happening. Note that JBL makes no claims of that in their description of their waveguide technology.
I guess he's an idiot now that that he doesn't totally agree with you & you can't use them to totally disprove me. These "idiotic" sayings are found through out the article. You can have your opinion & I can have mine. both are covered in this article so let's please end this now. I'm sticking by what wrote in the review.
Great review. Came close to ordering an LSR310S today, but the idea popped up of replacing my LSR305 with LSR308, and needed to be looked into first before finally being rejected. If If there was more space in from of the desk, the 308 might have worked. Imo 5" monitors are borderline acceptable in terms of size for desktop mounting, but the JBL's sound so-o-o good.
I listened to the 308's & was considering buying them but were way over kill on the bass. Some reviews mentioned the same. The 305's were better balanced through their spectrum than the 308's. midrange was still quite good on the 308's though in spite of the overdone bass. I would only go with the 308's if you quite a large room to soak up some that bass. not good for smallish rooms, even guitar centers somewhat large room was rather over powered by the 308's
My listening space is acoustically compromised as it is, so I'm sticking with the 305. Tweeter to ear distance while at the computer is 32", maximum would be 45".
My LSR310S should arrive in a week or two. Not sure if it would be helpful to set the LF Trim to -2dB, as the manual gives little reference to how to use than control.
you get your sub yet?
Sorry for the late reply. The LSR310S came and went. Tried to make it work but sold it because it crowded my work space. In terms of audio imo its an excellent+ match for the LSR 305. Was really sad to see it go.
