While I don't disagree that the noise floor of 16bits is practically inaudible, it can be heard on silent passages if turned up a little and the room is reasonably quiet. I know I can and so could most of the subjects in the Meyer and Moran study.
Sure you can hear noise, it's the noise floor of the recording, not the digital noise floor though! The Meyer and Moran study just truncated to 16bit, not even triangular dither was applied, let alone noise-shaped dither!
(1) A loud SPL is 96dBA, yes, but that is an average not the peaks of the waveform. A good rock recording has a DNR of say 16dB, so the peaks are 112dB if you don't clip (this is from the loudness database. I am not convinced of the workings of the DNR meter they use from FOOBAR). That leaves the noise floor of CD at 16dBA (OK 13dBA as there are 2 channels to make the 96dB). Fine, thats more than 14dB below the 30dBA people are talking about here.
(2) Remember the 30dBA talked about isn't white or pink noise in the background. It is general domestic interference.
(2a) It is entirely possible that the 16dBA background is audible, especially if near field monitoring.
(2b) However more dynamic music exists, and people listen at higher levels for the short peaks.
(3) Also the noise floor of the CD player is going to have other noise added by the system.
(4) I didn't ask for MORE than 150dB! I'm not crazy!
(5) By the same token, low frequencies need more power to be perceived the same, so as most music has all the energy at low frequencies (as MQA papers show all the way into ultrasonic - see: back on topic), more dynamic range is needed to reproduce it. The bottom end at say 40Hz needs 34.5dB extra, so that loses you 34dB - 8.5dB dynamic range for unclipped middle C (ish).
(5a) Presence band is where we are so sensitive so we will hear the hiss. Unfortunately PCM does not compensate for this, apart from a token amount at the top end if someone bothers to noise shape the dither.
1. Complete nonsense! You are comparing the DR database (which is similar to a crest factor measurement), with dBSPL peaks and dBA of the noise floor of CD. All of this is nonsense, you are comparing apples with oranges and from that comparison, coming up with the conclusion that aircarft shouldn't be made of concrete??!
2. Huh? "General domestic interference" in a quiet environment is random noise, not mathematically identical to pink or white noise but audibly extremely similar.
2a. Nonsense! In a very quiet room, how are you going to hear "A" weighted random noise that's 14dB below "A" weighted random noise? But your 14dBA figure is nonsense anyway: Read the responses given to you and if there's something you don't understand ask, DON'T just keep making up more nonsense!
3. And that's going to be the same amount of noise whether it's 16bit or 300bits!
4. Either you are asking for more than 150dB, in which case you're crazy, or you're making up nonsense facts and conclusions to argue for more than 150dB without even realising it, in which case you're crazy!!!
5. Again, more nonsense! How many recordings can you name with more than 96dB of dynamic range? There's only a handful or so with more than 60dB!
5a. Congrats, a complete full house of nonsense! 1, ~20dB is not a "token amount"! 2, Noise-shaping has been industry standard practice for nearly 20 years.
(1) Back to MQA from a computing viewpoint, I can't bend my head around the concept of a lossy codec that would beat a non lossy one...
(2) as I understand the creators of the codec want to control the whole chain from the microphone to the speaker does that mean the ADC ...
1. There is no getting one's head around that!
2. That's what they want you to understand but it's a marketing lie. It's a lie because it misses out by far the most significant part of the chain, the mixing/processing! The ADC and DAC are completely insignificant compared to the mixing.
(1) A handful is still some, and the argument is was that 16b is enough. MQA when decoded offers more ...
(2) It is not hard to offer 20 bit or more performance ...
1. No it doesn't, where did you get that from? According to the patent application, MQA offers 13-17bit.
2. Correct it's not hard, it's impossible!
(1) He measured instruments and found that there's life to the sound they make above 20kHz.
(2) He also leaves open the possibility that bone conduction can affect our enjoyment of music. He points to a study on that as well as to one showing electrical activity in the brain produced by frequencies above 26kHz.
1. Did you actually look at what you posted? Fractions of a percent at freqs which only young people can hear and even then, only if you blast them with pure tones! So, if you're young, have a collection of recordings of nothing but pure >20kHz sine waves and play them back at >100dB, then yes, >44.1kHz sample rates would be worth it for you!
2. He does leave it open, as a marketing ploy, because there is ZERO evidence to support it! Brain activity was measured BUT none of the study participants were actually aware of it. So, if you mechanically bolt your speakers to your skull, you're "enjoyment of music" will be unaffected UNLESS you enjoy watching a real time EEG while you're listening to your music!
(1) Throughout this thread when talking about timing error in the uS size, the ear's sensitivity is highest between arrival between the ears. This is below 20kHz. Also note the first arrival of the sound it the one that give those queues.
(2) The reflections of the room tend to be masked out when it comes to spacial awareness.
1. Only the marketing BS and those repeating it talk about uS size! Positional cues are in the ranges of milli-seconds, not micro-seconds, as has been explained in this thread on several occasions and to you personally! It's trivial to run a test and see for yourself, so instead of keep repeating the marketing lies, why don't you find out for yourself if you don't want to believe what we're telling you?
2. That's completely backwards! It's the reflections of the room/environment which gives spatial awareness.
G
