The back of the sub has the usual 3, 3.5mm ports for 5.1 audio which are "Front", "Rear" and "Center/Sub". It also has a single RCA port where each of the speakers plug into. I did not use a splitter, in fact I don't have one, otherwise I wouldn't have asked - I would've just tried it myself.
Here's what I did(using only ports on the sound card):
1. At first, I had the "Front" output on my sound card connected to my external amp and I wanted to add the sub to get a 2.1 system. I connected the sub using a mono(3.5mm) cable to the "Center/sub" output on the sound card(That was the only connection). That alone was not enough to "power" the sub. When I ran the windows 5.1 sound test, the sub barely vibrated.
2. I disconnected my external amp and instead tried running the "Front speaker" line into the sub. That's when the sub was "powered" properly and it was playing normally. I t was just the sub( no speakers connected to it) but I had to run 2 lines into it, 1 for the Front speakers, and the other for the "Center sub".
Conclusion: This lead me to think that the built-in amp in the sub works in such a way that it needs to have the "Front" port connected no matter what.
Now my question is, can I use a splitter for my sound card "Front" speaker output so that I can run 2 lines from it - 1 for the external amp, and the other for the sub?
Thanks
