joeq70
- Sep 26, 2007
EDIT: UPDATE!!!! PLEASE NOTE THAT TIDAL NOW OFFERS WASAPI SUPPORT NATIVELY. SHOULD BASICALLY SOUND THE SAME AS JRIVER, BUT YOU DON'T HAVE VST PLUGIN SUPPORT IN TIDAL FYI. ONLY USE THE BELOW GUIDELINES IF YOU FOR SOME REASON REALLY NEED TO RUN TIDAL THROUGH JRIVER.
Hello all! I decided to make this thread just in case someone out there finds themselves in the same position I was in a couple weeks ago. I decided to give Tidal FLAC streaming a try for a month, and by the end, I found myself wanting to cancel the service because the overall sound quality using Tidal in Google Chrome was inferior to listening to the same FLAC rips when played on my PC through JRiver Media Center.
The ultimate cause of this issue was that Tidal through the Chrome browser is forced to run via Direct Audio--this means that even though I had great quality files streaming from Tidal, the audio was being run through windows mixer which ultimately caused two issues for me: 1) slightly smaller soundstage and 2) slightly less bass. I previously avoided this when listening to my personal FLAC collection by setting up JRiver to play in WASAPI dedicated mode. Thankfully, I did a search to see if it is possible to run Tidal via WASAPI (or ASIO) and...there is!
Please note that I use JRiver Media Center...I do not know if this method works for Foobar or any other audiophile-friendly media player. Feel free to report success/failure with another program. Anyway, here is how you do it:
1) Download and install JRiver Media Center. You can download a free trial here if you are curious and want to see if you notice a difference.
2) Open JRiver, then navigate to Tools>Options
3) Select "Audio" on the left and you will see a carrot on the right where you click under the heading "Audio Device."
4) Select your DAC and make sure either [WASAPI] or [ASIO] is at the end of the name. I use WASAPI because my DAC only supports that. I'm assuming that those who want to use ASIO can also use this method I'm describing.
5) Click the button just below the name of your DAC labeled "Device Settings"
6) Checkmark the box that says "Open device for exclusive access." Click OK
7) Click OK on the options menu. JRiver is now set up!
8) Click here to Download and install the latest Tidal desktop app for PC or Mac.
9) Open the Tidal Desktop App. Make sure JRiver is still open as well.
10) In Tidal, click "Settings" on the left side menu.
11) Click the heading labeled "Streaming"
12) Under "Sound Output" select the option that states "Speakers (JRiver Media Center XX ) "
Congratulations! You may now play songs in the Tidal app and get the befits of circumventing Direct Sound and instead use WASAPI or ASIO because the Tidal audio now streams directly through JRiver!
The only drawback is that so far I have to go to Settings>Streaming>Sound Output then select Speakers (JRiver Media Center __ ) every time I close and reopen the Tidal App. It seems this setting doesn't save by itself. A small price to pay for a noticeable increase in quality!
Happy Listening!
Happy Listening!
