brokentofu
- Aug 16, 2015
No. You can select an output coupling capacitor to push the bass cutoff well below audibility, but an electrolytic that size with low-impedance planars will cost more than an output transformer. At the same time, it does nothing to increase the current. You get what comes off of the tube, period.
Contrary to the post above, output transformers (good ones) only need two impedance outputs to match well with just about any headphone impedance on the market. Things are not that precise in matching impedances. 32 or 300 will work quite well for Grados, THX00's, AKG 701's, and HD800s. All that requires is a DPDT switch - a single one for both output transformers. Edcors run about $10-$15 each, that way. You'll spend a lot more on the tubes.
BTW, an output transformer is much more transparent than an output electrolytic capacitor. OTL gives up a lot, IMHO.
Is there a build you you suggest for using the cheap output transformers? Something that has a PCB or well documented enough to be someone's first point to point?
