Bubblejuice
- Nov 28, 2016
I just got a pair of old HD 595s, so i'm experimenting with them with light modding, considering they only cost me $20. The pads were gross, I washed them and now they feel good.
But just before that a thought crossed my mind...
Since I use beard oil pleather and leather bands and pads when I want to rejuvenate them a bit, and considering the magic that beard oil does to beards. Would a light rubbing of beard oil with a cloth on the velour pads do the pads good or bad?
I tried a little dab on them before I washed them, that spot became incredibly soft. But I'm not sure what would happen if I applied it to the whole pad. So far beard oil works great on leather and pleather. Once it's absorbed it doesn't seem to go bad like cooking oil would. Also, it doesn't make my head oily once it's dried for a few minutes, but obviously velour is a completely different thing than leather, so i'm not sure.
Any ideas what the result would be? (I'll probably try it anyways if no one tells me otherwise )
Thanks!
Thanks!
