FredA
- Dec 15, 2013
After few days run-in on a working boot up I am not sure which DAC I like better - M7 upgrade or S7. First, I now realize now how much the Singxer SU-1 HDMI I2S adds to my pleasure of both of these DACs with the Singularity digital boards. The highs are clear and open with SU-1 - like no other input or DDC I have ever tried.
Does everyone understand High Exact mode on I2S inputs with the Singularity digital board? With High Exact mode engaged (tighter PLL lock) I2S input vocal sibilance is more refined, more detail, and soundstage firmer. High Exact mode requires a good clocked DDC and cables. Low Exact mode is good as well but just a little something extra with High Exact engaged. The Singxer SU-1 works well for High Exact mode on both these two SIngularity digital board DACs.
Here's a explanation of High Exact mode, I2S, and the BYPASS jumper for DACs with the Singularity digital board.
"All inputs on the Audio GD Singularity M7 and new R2R 7 DACs operate in "High Exact" clock recovery mode (very high bandwidth) for lowest jitter and best performance. On I2S inputs source clocking and cabling must be stable and sufficient quality for "High Exact" to operate reliably. If you experience audio dropouts or noise on HDMI or TTL I2S playback try placing a jumper on DSP BYPASS = On. This forces I2S inputs into a lower bandwidth/ wider lock window mode with only slight affect on sound quality. I2S input default has "High Exact" mode Enabled (BYPASS = Off). And the BYPASS jumper only impacts the I2S inputs."
I now want to hear the R2R 7 with the Singxer SU-1.
I will be able to give you a hint of how things sound within a few hours, using my super usb chain ending with the singxer f-1 feeding the r2r 7 through rj45 i2s. Pll on for a start. I am home now, waiting for DHL to knock on my door.
