amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
The second run of the boards is being done as a group buy at Headwize. If you're interested in the board and have not signed up yet, you can do it now.
Originally Posted by amb /img/forum/go_quote.gif The ε24 circuit itself draws very little current. Most of the current is pulled by the relay coil, so your relay choice is what determines whether a particular transformer is good enough. The 1.5VA spec is good for the Omron G8P relay. Yes, thermal compound should be applied to the thermostat's heatsink mating surface. |
Originally Posted by amb /img/forum/go_quote.gif luvdunhill, see Note 4 under the "Parts list" section of the ε24 website. Many SSRs' control inputs draw so little current that the thermal sensing feature may not work without adding a resistor as specified. |
