I use the Focal Bathys and I do find that the volume is not very loud especially with a wired connection.
SONY NW-ZX700
- Thread starter leylandi
iskender299
I buy 90% of the music so I mostly use Sony's app.Just wondering what audio setting people use on the Walkman, I have just received mine and I have finished debloating google and was curious on how people set the unit up. I am using Tidal and Senniehauser IEM 600 with it.
I also have Tidal and Apple Music, but that's more for testing new albums before buying (or listening to stuff that are impossible to find to buy).
If HR or DSD, I use Direct.
If CD and rarely compressed (cough iTunes, cough), I use DSEE
High gain on, balanced
Sometimes I'm in the mood to use the DSD Remastering.
I am having trouble transferring music to the unit using the Sony music app. It says it has been transferred but it is noon on the unit. I am confused. Any help would be appreciated.
musingclouds
- May 27, 2011
Use a computer, if on a Mac can use android transfer app.I am having trouble transferring music to the unit using the Sony music app. It says it has been transferred but it is noon on the unit. I am confused. Any help would be appreciated.
MudEnjoyer
Definitely buy a SD card adapter before dealing with that crap.if on a Mac can use android transfer app
Don’t forget to put the music on the Music folder!
If using a microSD card, much simpler to take the microSD card out, and put it into a card reader, plug it into a PC to do the transfer. All music must go into the "music" folder, whether it is internal memory or microSD card, as Sony only scans music from this folder.I am having trouble transferring music to the unit using the Sony music app. It says it has been transferred but it is noon on the unit. I am confused. Any help would be appreciated.
Six months after purchase in Japan, I now enjoy my ZX707 with a Focal Elegia w/ Maze balanced 4.4mm. Good combo, even if some EQ and running-in needed.
And to answer posts above, no issue with Android File Transfer on Mac (not the app of the decade neither).
Has anyone successfully removed volume capped yet?
No, on the Android based Gen 2 models (WM1A/Zm2, ZX707, A306)Has anyone successfully removed volume capped yet?
Yes, for the older non-Android Gen 1 models ( WM1A/Z, ZX300, A4/5 series)
musingclouds
- May 27, 2011
Does anyone know if this will also fit the ZX707?
https://www.aliexpress.us/item/3256...2791770.1005004667392549&gatewayAdapt=glo2usa
Death_Block
Quick question, is the output for the zx707 able to do what the chord mojo 2 does? Running the HD700 and Ibasso SR3. I had the 507 that struggled with the LCDi4. But I'm not powering the LCDi4 anymore with daps. I realise they are completely different but if a nice dap that has the musically of the mojo 2. I'll buy another one. If Sony has the power I'll sell the 507 and get a 707 in an instant. But I suspect it won't against the mojo 2. I can do without a DAP but if the 707 is platinum, I'll get it. I love the players without shelf chips
SolarCetacean
The ZX707 won't have the same power output as the Mojo 2. The Mojo 2 spec is 600 mW into 30 Ohms (4.2V RMS). The uncapped ZX707 does 230 mW into 16 Ohms (1.9V RMS) over its balanced output, and 50 mW from its 3.5mm output.Quick question, is the output for the zx707 able to do what the chord mojo 2 does? Running the HD700 and Ibasso SR3. I had the 507 that struggled with the LCDi4. But I'm not powering the LCDi4 anymore with daps. I realise they are completely different but if a nice dap that has the musically of the mojo 2. I'll buy another one. If Sony has the power I'll sell the 507 and get a 707 in an instant. But I suspect it won't against the mojo 2. I can do without a DAP but if the 707 is platinum, I'll get it. I love the players without shelf chips
From a quick visual compare, it will not fit the ZX707. The distance between the two sockets on the ZX707 is clearly smaller.Does anyone know if this will also fit the ZX707?
https://www.aliexpress.us/item/3256804481077797.html?pdp_npi=4@dis!USD!US $109.99!US $109.99!!!109.99!109.99!@2101e80f17153774462175812e2b5a!12000030039023592!sh01!US!0!&spm=a2g0o.store_pc_home.productList_2008412791770.1005004667392549&gatewayAdapt=glo2usa
musingclouds
- May 27, 2011
Does everyone here use the Walkman app for battery considerations or are things like UAPP better?
Curious if anyone has A B tested.
Death_Block
Hmm, might stick to the mojo 2 path then. Plus will double as desktop and dac.The ZX707 won't have the same power output as the Mojo 2. The Mojo 2 spec is 600 mW into 30 Ohms (4.2V RMS). The uncapped ZX707 does 230 mW into 16 Ohms (1.9V RMS) over its balanced output, and 50 mW from its 3.5mm output.
Total: 5 (members: 1, guests: 4)
