I spotted some measurements from MusicTeck's website for the SendyAudio Aiva which I've manually drawn over with a white line for better clarity:
https://cdn.shopify.com/s/files/1/0...son_Between_AIVA_and_P-II_by_SIVGA-2.pdf?1502>
Inpsired by these measurements, I shifted my Aiva around the rig to get measurements that correspond to this graph:
(MiniDSP EARS. 500Hz 84dB normalized. No Smoothing. Purr1n's Compensation)
With these new measurements I came up with a second EQ that corresponded to these measurements
Preamp: -8.43 dB
Filter: ON PK Fc 20 Hz Gain 2.5 dB Q 1
Filter: ON PK Fc 50 Hz Gain -0.7 dB Q 2
Filter: OFF LSC 9 dB Fc 105 Hz Gain 5.5 dB
Filter: ON PK Fc 250 Hz Gain 0.4 dB Q 4
Filter: ON PK Fc 500 Hz Gain -1.4 dB Q 3
Filter: ON PK Fc 560 Hz Gain -0.6 dB Q 7
Filter: ON PK Fc 700 Hz Gain 1.5 dB Q 10
Filter: ON PK Fc 760 Hz Gain -2 dB Q 4
Filter: ON PK Fc 830 Hz Gain 0.6 dB Q 10
Filter: ON PK Fc 900 Hz Gain -2.3 dB Q 4.5
Filter: ON PK Fc 1000 Hz Gain -1.8 dB Q 7
Filter: ON PK Fc 1085 Hz Gain 1 dB Q 15
Filter: ON PK Fc 1275 Hz Gain -1 dB Q 10
Filter: ON PK Fc 1400 Hz Gain -1.6 dB Q 9
Filter: ON PK Fc 1620 Hz Gain 8.5 dB Q 6
Filter: ON PK Fc 1666 Hz Gain -3.4 dB Q 20
Filter: ON PK Fc 1755 Hz Gain 1 dB Q 30
Filter: ON PK Fc 1900 Hz Gain -1 dB Q 20
Filter: ON PK Fc 1990 Hz Gain 1 dB Q 20
Filter: ON PK Fc 2150 Hz Gain 2 dB Q 20
Filter: ON PK Fc 2200 Hz Gain 4 dB Q 4
Filter: ON PK Fc 2800 Hz Gain 5 dB Q 7
Filter: ON PK Fc 3000 Hz Gain 2 dB Q 0.8
Filter: ON PK Fc 3100 Hz Gain -2.8 dB Q 5
Filter: ON PK Fc 3400 Hz Gain -2 dB Q 14
Filter: OFF PK Fc 5900 Hz Gain 7.8 dB Q 7
Filter: ON PK Fc 7000 Hz Gain -1.4 dB Q 10
Filter: OFF PK Fc 9500 Hz Gain -10 dB Q 7
Filter: ON PK Fc 13200 Hz Gain -6 dB Q 4.5
(How it looks by default, with optional settings OFF)
Functions of my EQ:
Boosted sub-bass to be level #1-2
Made uneven mids more linear #4-12
Made upper mids less recessed #13-23
Kept the lower treble level as I felt it was just nice #24-25
Lowered upper treble peak #29
Optional EQ Settings (OFF by Default):
#3: Filter: OFF LSC 9 dB Fc 105 Hz Gain 5.5 dB (Harman +5.5dB Bass Boost)
#26: Filter: OFF PK Fc 5900 Hz Gain 7.8 dB Q 7 (Rtings PTRF Soundstage Boost)
#28: Filter: OFF PK Fc 9500 Hz Gain -10 dB Q 7 (Rtings PTRF Soundstage Boost)
(Rtings PTRF are to be used in conjunction - need to have both #26 & #28 ON)
