zest
- Jul 19, 2010
Wow, this was pretty clever to get an idea where to block of the back area.
Yes, and the diameter is constant.
Are you referring to the whole album or just the one song called Break The System. How many hours do you burn in at a time?
This sound plausible. So, more foam means less room? Or the positioning of the driver relative to the housing not being consistant.
I doubt that the factor is a variation in quantity, if quantity wasn't machined to be the same we would have gotten a lot of pairs with channel imbalance. If what causes variations is indeed the foam, the likeliest factor would probably be inconsistencies in its quality between batches.
Completely blocking the vents has a relatively minimal effect on bass quantity though, so i have my doubts about the foam theory, but it's definitely worth checking out.
A few more pics. Poor quality, since I don't have a lightbox. And holding a flashlight in one hand while doing manual focus with the other is pretty challenging.
I didn't succeed in separating the cable sheath from the strain relief and pushing it to the inside (maybe the opening isn't wide enough). But I got a better look inside:
You can see the foam piece is actually pretty small and located between the cables:
Removing the foam exposes what seems to be some sort of back vent in the driver enclosure:
Back vent plate and front vent plate. It's like a chastity belt to prevent dynamic driver mods.
Anybody know what the purpose of the foam is? It's covering the vent I know, but why is it there? What would happen if that is taken out and used?
Interesting, I do know for a fact that the foam behind the driver is there to reduce bass. Add more foam and I guarantee the bass is reduced even more.
Yup, less volume in the back=less bass
less volume in the front=less treble
Rin demostrated this in his 9927 and MH1 mods.
See quotes above yours.
I take it you're only skimming the thread.
If bass variation can be changed with foam mod but keeping rest of spectrum and matching the reference pair, it would be cool.
