docentore
- Feb 27, 2013
Anyone can explain the buttons on the M400+ or take photo of manual please? Got one with no manual but can't change source to usb
Hi!Anyone can explain the buttons on the M400+ or take photo of manual please? Got one with no manual but can't change source to usb
Actually the DAC works while charging i my unit.Hi!
1 - balanced out 4.4, volume controlled
2 - 3.5 out, volume controlled
3 - 3.4 line out
4 - USB in
5, 6 - track forward and back, should be supported with software, i.e. works not everywhere
7 - short press - stop/play, works if supported with software, long press - switch bluetooth on or off
8 - gain control (amplification level)
9 - on/off, when on - short press changes digital filters
charge port on the back, DAC may not work when charging. Also mike and bluetooth LED are on the back.
My m400+ switches itself to USB automatically when USB port connected onto port 4 at the picture.
My m400+ works with the phone only via OTG cable, not with regular usb-c cable.
The easiest way is to plug an OTG adapter like the one pictured into the phone and then you may use regular type c to usb cable. As for me, cabled connection outperforms bluetooth substantially.So need to get USBC otg cable. Right.
Altough i'm fine so far with LDAC.
Thanks.
PS. Track control is all over the place, but not sure if I'll ever need. It is not going to leave my home. Using xDSD as portable on the go
I seem to have a very early version of the m400+. Support told me that the firmware update will only happen if serious bugs are detected in the device.Actually the DAC works while charging i my unit.
Any firmware upapdates etc available?
Thank you, very interesting charts! Can you do the same for the different filters, at least for a couple or three of the seven available?
I would just like to point out something I noticed about the YinLvMei M400 Plus.
I always knew that the M400 Plus increased IEM's bass and reduced the treble response. But I thought it was just an internal DSP they added.
However, testing all of the output ports of the M400 Plus, I realize that it may not be a DSP filter, but rather simply due to the Output Impedance of each port.
The LO port adds the least amount of color to the IEM sound, but still has reduces the treble, compared to the Fiio M11 "neutral" sound.
I'm contacting YinLvMei to clarify, but everyone should be aware that the M400 Plus is going to add varying level of "color" (increased bass & rolled treble) compared to other devices such as the iPhone dongle or DAPS.
Got that adapter, it does work with my phone unfortunately. I'll stick to BT connection.The easiest way is to plug an OTG adapter like the one pictured into the phone and then you may use regular type c to usb cable. As for me, cabled connection outperforms bluetooth substantially.
May I know if these tests/charts are based on M400plus (AKM version) or M400E (ESS version)?
I tested all the different filters on Gain 2. The turquoise one is Filter 1 on Gain 1.
None of them makes an impact on IEM's frequency response
https://xduoo.net/product/type-c-to-type-c-cable/ This one works fine for me.Got that adapter, it does work with my phone unfortunately. I'll stick to BT connection.
