stv014
- Jul 17, 2011
Do you have a front panel headphone jack ?
It is not as good as the E11, but should be OK, and is cheap, and does not use batteries either. With the prices at your location, it might be the best choice, other than the PCI slot issue.
I didn't know that the onboard has an amped line output. To my knowledge the headphone jack is the line out also there is subwoofer, side speaker, rear speaker, mic and line in jack. Nothing more.
From what i reading the DX wouldnt be enough to replace the onboard solution. What do you think about the DG?
