I call ******** on the marketing story. Graphene diaphragm? hahahaha That material is crazy expensive.
Reminder that they had beryllium diaphragm before, on the 2.0
Plenty of results would be a serious stretch. Each result I found most sensibly attributes the occurrence to static electricity. The cloth cable rubbing clothing is the likely source of the buildup, and the metal shell provides the path for the discharge. Other brands were reported as causing a similar effect - this is not a Xiaomi exclusive. Certainly the inner ear can be a rough place to get a static electric burst. Current won't be high, but voltage can be in the tens of thousands. The electrons are just waiting for a place to go. If the grounding to 'earth' of the cable/player/computer isn't good, your body is as good a place as any for those electrons to jump. Yowser!
Short story? Bad ground, good static, nasty zap. Static happens.
Well you can't deny there's an anomaly if it only occurs on one earphone, and not the other. But one way or another, there's either a defect or a design flaw. Haven't got the time and care to dremel the earphone, but my educated guess is that the electrical components in the left earphone started to touch the metal housing. You don't have to be an engineer to acknowledge that such an occurrence could've been prevented by either implementing proper isolation, or by eschewing a metal housing that basically becomes a conductor.
After 6 months or so, mine have probably become defective. The left earphone has started to pass an electrical current onto my ear. Very painful. Coincidentally I've its successor on order, but if that one will show the same defect at any point in time, I'll definitely reconsider buying Xiaomi earphones. Apart from pain, not going to play roulette with my health.
Guys, I have Mi piston 2.1 (2014 iF award edition) and it still running strong after 1000++ hrs of usage. One thing that really bothers me is my ears getting itchy after using it for around 1 hr or so. I thought it's the tips, so I different pairs of foam and silicone tips, but the itching is still there. I have some other IEMs and earbuds, with plastic and metal housings, and I never feel the itch with other pairs. I've clean my piston 2 like plenty of time, way more than I clean my other pairs, with water, dishwasher, alcohol, even H202, but still.
I think I'm allergic to the metal housing material of piston 2. My question is, does this hybrid still using the same material?
Hi there, new subscriber here although I've been lurking for a few years. I have a question for you guys regarding the Xiaomi In-ear Hybrid Earphones Pro.
The first set I bought from Gearbest was defective, the left speaker was much louder than the right speaker
This was replaced by another set but now the right side seems to be failing again, the volume is much lower. When I wiggle the cable a bit everything is fine again (as opposed to the first set).
I did not mistreat these things and generally my in ears work fine for years (until I lose them), has this happened to other people? I'm interested in this because two defective headphones within 2 months is too much hassle and I might need to buy another brand/model. If not, I'll RMA them again.
From my experience I don't think you're "allergic" to the 2.1's metal per se; rather, the 2.1's laser-cut disc pattern may be the one scratching your ear. The Piston Hybrid uses a smooth metal for the exterior part of the housing, and plastic for the nozzle area that makes th emost contact with your ear.
Hope this helps.
If the laser cut itself is the culprit, then more people should've reported similar symptom. But IDK, haven't use another 2.1 my whole life, maybe it's just my unit, or my earlobes are just hyper-sensitive (or it's just me tryna feel special among others, lol).
Now knowing the hybrid is using plastic for the nozzle area then I'd really consider to get one because most people say it's a great upgrade path from piston 2 (or 2.1).
Oh, another question, I love old school hip-hop (ATCQ, Slum Village, Mos Def, Kwelli, Common, Outkast, The Roots, etc) and classic 70's reggae / dub (The Wailers, Gregory Isaacs, Dawn Penn, Desmond Dekker, etc).
Which one should I get, the original hybrid or the pro version? I wish to get something like my piston 2.1 with better highs without being too sharp or sibilant.
In my opinion the Xiaomi is quite a bit better than the Kz phones. It's only my opinion but I own almost every model of Kz phone that is worth anything sonically.
Just my opinion but my Ates and Ed9 remain in my drawer.
TWIN
