XDUoo XD05PRO
Apr 15, 2024 at 12:29 AM Post #2,056 of 2,325
Burson audio V7 Vivid ~I like it more than I expected.
Among all my op amPs, V7 is a representative one, with accurate sound positioning, pure, transparent and vibrant listening experience.
Compared to the V6, the new V7 is worth an upgrade. The sound base is clearer, the density and intensity are increased, and the sound field is more transparent, wider and farther.
Apr 15, 2024 at 1:09 AM Post #2,057 of 2,325
Will you create a top ranking? (thanks, nice collection)
Apr 15, 2024 at 8:58 AM Post #2,063 of 2,325
Apr 15, 2024 at 9:19 AM Post #2,064 of 2,325
Ufeel op-amps upgrade board came in the mail, bought from Ufeel Taobao official store.
For those who want more thicker mids and more airy sound can consider this.
Apr 15, 2024 at 9:29 AM Post #2,065 of 2,325
I ordered a pair of those. The OPA627 to pair it with just arrived today.
Apr 15, 2024 at 9:44 AM Post #2,066 of 2,325
OPA627 is single channel, you will need a adaptor to put 2 pcs to become dual configuration.
Apr 15, 2024 at 9:56 AM Post #2,067 of 2,325
I probably need to return it too, but in my country, unfortunately, nothing can be returned without numerous courts.
Xduoo support takes several months to respond.
p.s. This is what they just answered
Hi,
If you use high-sensitivity in-ear earplugs, there is a slight white noise, which is normal, because XD05PRO has high output power, its minimum gain (ECO), and also has 12DB (unbalanced) / 16DB (balanced) output.
If you only drive high-sensitivity in-ear earplugs and do not need so much outpower, you can reduce the gain of amplifier, that is, by changing several resistance values on the ear amplifier card, you can reduce the noise, as follows:
Change 2KΩ to 1KΩ value
Does it mean I have to desolder those 4 resistors and replace with some other resistors? Which should I buy? Some like https://www.aliexpress.us/item/3256805705482032.html?
Apr 15, 2024 at 10:12 AM Post #2,068 of 2,325
I bought the dual channel ones. I can see 2 ICs on each amp.
Apr 15, 2024 at 11:28 AM Post #2,069 of 2,325
The best partner for xd05pro:)tempotec v3-d👍👍👍
Apr 15, 2024 at 12:09 PM Post #2,070 of 2,325
I don't see the aes variant anywhere, can you provide a link? :relaxed: (Is it pure transport without HP out?) I read somewhere on the forum about this project some time ago. This is a great thing for dac/amps and dongles. Does it have global eq?
