Has anyone found a decent hard case for XD05 PRO that's about the same size as the device? I'm struggling to find one so any recommendations would be welcome.
XDUoo XD05PRO
- Thread starter jockwong
lapmic
If you mean a carrying case... I use this one. V cheap but I find it perfect for my use:Has anyone found a decent hard case for XD05 PRO that's about the same size as the device? I'm struggling to find one so any recommendations would be welcome.
https://a.aliexpress.com/_EHyjHqt
Thank you, that's just the sort of thing I am after - much appreciated.If you mean a carrying case... I use this one. V cheap but I find it perfect for my use:
this is the leather case on eBay, not a hard case. Still protects the unit form the scratch.Has anyone found a decent hard case for XD05 PRO that's about the same size as the device? I'm struggling to find one so any recommendations would be welcome.
Bengkia369
I'm using this, impressed with it's high quality leather!this is the leather case on eBay, not a hard case. Still protects the unit form the scratch.
gto88
- Dec 11, 2014
Received mine today, put it on charging first.
sofastreamer
- Dec 14, 2007
they allready stated it will be at the end of the yearAnd still no word on the R2R DAC either its not going to happen because it can't be or it got dropped.
gto88
- Dec 11, 2014
First impression, powerful, clean power.
Seems enhancing my iem (Mest mkii) further.
I have been doing a little more testing of the AKM and ESS modules with different IEMs. I'm using SS3602 opamps, source is typically Qobuz via a Quloos QU02 DDC and good quality Toslink optical cable. I haven't tried my headphones yet, but will get to that later.
I'm tending to find I prefer the AKM module with Subtonic Storm and Kinera Loki (Emerald version), whilst I prefer the ESS with ThieAudio V16 and TSMR X. I suspect that's due to the more relaxed overall presentation of the latter two vs the more precise delivery from Storm and Loki. There's not a huge amount in the DAC modules, but enough to warrant switching around depending on transducer, music, and preferences on the day.
The AKM module continues to appear slightly warmer and bassier, with marginally softer treble. The ESS feels a touch cleaner and more neutral overall. I wouldn't feel short-changed just using the stock ESS, but the AKM adds a subtly different flavour I feel is justifiable to me. Personally, I'd challenge the assumption that only one module is "best" - it really does seem to depend on transducer, music, personal preferences, and probably the weather!
VisalEziomi
Does XD05 Pro drive Subtonic Storm fully? Any lack of technicality like imaging, soundstage and detail retrieval? What's volume and still more headroom?I have been doing a little more testing of the AKM and ESS modules with different IEMs. I'm using SS3602 opamps, source is typically Qobuz via a Quloos QU02 DDC and good quality Toslink optical cable. I haven't tried my headphones yet, but will get to that later.
Fully? No. Well? Yes.Does XD05 Pro drive Subtonic Storm fully? Any lack of technicality like imaging, soundstage and detail retrieval?
Storm is best with desktop amps. I have a MASS-Kobo 394II, which drives Storm brilliantly. Really good quality desktop gear just seems to grip and control the drivers in Storm better than any portable device can manage. I have only tried HiBy RS8 of the top-end DAPs (320MAX, N30LE, M9 Plus, e.t.c) so can't really compare with those. However, I feel Storm is about as well-controlled with XD05 PRO as you'll achieve with a single portable device. In terms of value for money and ability to drive a wide range of transducers, it's impressive.
VisalEziomi
I want to save up for Storm! But i heard it one of the hardest to drive and i like portable not stationary. So XD05 pro is viable option.Fully? No. Well? Yes.
HardstyleLoco96
- Jan 21, 2014
Does anyone drive iems on normal mode? I found normal mode sounds better with iems compared to eco. Only point of eco is if the iem is truly extremely sensitive
hardykalyan
In the end its all about SYNERGY.I have been doing a little more testing of the AKM and ESS modules with different IEMs. I'm using SS3602 opamps, source is typically Qobuz via a Quloos QU02 DDC and good quality Toslink optical cable. I haven't tried my headphones yet, but will get to that later.
Starting with source, wiring, dac, wiring, amp, wiring, transducer, ear chamber, brain, heart & soul... Everything Counts
Absolutely agree, and that was one of the points I was trying to make. Approaching audio with an open mind being another.In the end its all about SYNERGY.
