alicaria
- Jun 22, 2015
Hi.. I'm looking for a tube amp, I don't need a DAC.. so, which would be better the xduoo TA-02 or TA-03?
Ta02 can be beter for you
03 more professional
Can anyone recommend this as a desktop Amp/DAC: https://www.massdrop.com/buy/xduoo-ta-01-dac-amp
Tested it with a Win7 laptop and it worked fine. Very warm, somewhat thick-sounding with decent sound stage. Good power. I used a DT880 250 ohms. Returned it; just not my cup of tea.
... There are 2 Gain jumpers.
Stock is both set to HIGH not Low, so I may try setting them to Low at some point.
Both 5814A and 5963 are both very good on xDuoo TA-01, but I still want to try something different.
So here it is, Sylvania 12BH7A in place of 12AU7:
I have asked xDuoo and they clearly stated that 12BH7 can be used in place of 12AU7, that's reassuring.
However, as the weather gets hotter, so as the temperature of TA-01, though it still functions well...
This is a grey oval-plate, D-getter 12BH7A with yellow Sylvania marks (almost invisible now).
I can't tell the difference between Toshiba 5814A and Toshiba 5963, but the upgrade to 12bh7a had significantly improved the sound stage, warmth and speed.
Some have argued that 12au7 is more emotional than 12bh7, however, I found the opposite. Maybe these Japanese tubes are more neutral?
Next I would like to try 6350, however, I can't find an adapter for it now...
