Is the WA22 fuse size a 5x20mm (0.75in) or 6.3x32mm (1.25in)?
here is some info: https://www.head-fi.org/threads/woo-audio-wa22-amp-owner-unite.826386/page-159#post-17917620
I use mine as a preamp, probably more than for headphones. The volume knob works the same in pre mode as it does for ‘phones.Do any of you use your WA22 as a preamplifier?
I have a new solid state amp on the way and I'm told it does well when you use a tube amp as a preamplifier. When you set the WA22 to the PRE setting on the dial, is the output from WA22 set to a certain level/gain (dB) and voltage, with the volume on the front being inactive?
OK, thanks. Curious how one knows the correct level on the WA22 so you don't overload your second amp?I use mine as a preamp, probably more than for headphones. The volume knob works the same in pre mode as it does for ‘phones.
I believe Woo recommends setting your volume at 12'oclock if you are using your WA22 as a pre. Then use the volume on your other amp as needed (assuming it has one). If you need "more" power, push the WA22 volume up from there.OK, thanks. Curious how one knows the correct level on the WA22 so you don't overload your second amp?
Question to 1266 users with WA22. Do you use LO or HI impedance? I notice LO give more relaxed and laid back sound, with depth to soundstage. HI is more aggresive, "in face" sound, forward.
They shouldn't make significant difference in sound, but I support the Canadian one. Every product made in Canada that I bought so far never gave an issue.Hi guys !
Which of these tubes is better?
https://www.langrex.co.uk/products/5u4g-brimar-orange-print-nos-valve-tube-lc83/
https://www.langrex.co.uk/products/5u4g-brimar-canada-nos-valve-tube-t12b/
Thank you !They shouldn't make significant difference in sound, but I support the Canadian one. Every product made in Canada that I bought so far never gave an issue.
IMO at this level it isn’t about “better” it is about which one you like, and then the specific tube you receive. If I were to pick I’d take the hanging filament, but that doesn’t make it best for you. YMMV and all that.Thank you !
What is the difference between "HANGING FILAMENT, FOIL GETTER" and "SOLID GETTER"?
What's better ?
