As far as I know and just recently learned all tube amps should have a load on the transformer all the time. Either speakers or headphones. If not it can ruin the transformer or transformers. If they are ruined then ya might as well throw the amp away as they are the most expensive part of a tube amp. I have read that the Woo amps have some tolerance to not having a load however the best practice is to always have something connected. When I have just rolled new untested tubes I always just plug in crappy headphones until I am satisfied the new tubes are safe. Usually after 5 minutes.
I'm not a expert on this so there can be some mistakes in the above statement so other more experienced members could probably tell us more.
OK, so I'm now going to start practicing powering on my WA6 up with the HP's plugged-in.
Now what about when powering off…should I leave the HP's plugged in also, then after the amp is powered off un-plug the HP's?
Another thing is, I've mentioned the way I power-on/off the WA6 many times before when this question was asked…I hope this hasn't caused any potential damage to anyones WA6!
