With what and how should I clean my headphone pads?
Jul 27, 2009 at 3:38 AM Post #7 of 11
Not sure if it's leather, Could be some fake wannabe leather most likley.
The headphones in question are the ha-rx700s
Also, the headphones don't smell bad, but only if you like sniff them up close/.
Jul 27, 2009 at 3:39 AM Post #8 of 11
This might work:
Disassemble the pads from the headphones, and lightly rinse with soap and water. Leather/Pleather can handle some water.
Wait... what headphones do you have?
Jul 27, 2009 at 3:55 PM Post #9 of 11
Damp soft cloth, perhaps even with a little dash of soap.
Or disassemble the pads and wash the properly in warm soap water.
Jul 28, 2009 at 4:47 AM Post #10 of 11
I actually use leather conditioner on leather pads,keeps them clean and in pristine condition.
It keeps them soft and supple,if you treat them properly leather pads should last a lifetime.
PS, I also use it on the pads on my CD3000 and they are not leather,but it keeps them in good condition.
Jul 28, 2009 at 11:47 AM Post #11 of 11
similar question here. the pleather pads of my ath m50 became a little bit stiffer as they used to be when i bought them. they are only 2 month old now...is this normal for pleather pads or is there some care product? ... ah and, yes i wash my hair and face on a regular basis, just if someone suggests this :wink:
