Any way to go wireless usb from laptop to musiland 02? Is this still not really possible? Do you think there will be really good dac/soundcards that have wifi in the near future?
There are these, but I wouldn't trust it. The problem with wireless is that it's a lot slower than wired connections, and a lot less reliable. IE: That device can only go 54mb/s AT MAX. If your device needs more than that, you're toast. Also, it says to not use latency sensitive devices (IE: Webcams or printers.)
Cables are gold, wifi is not the future, with quality in mind.
