Will inserting a earphone/headphone into an amp with volume knob not at zero cause electrical surge and damage?
Jun 22, 2020 at 10:31 AM Thread Starter Post #1 of 5
baskingshark
Hi, would like to defer to the advise of our friends here about the above question?
Would inserting a earphone/headphone with a running amp (not at volume zero) cause some electrical surge and damage equipment? Would it be better to turn off the amp/put volume at zero?
For that matter, does turning on and off equipment regularly cause electrical surges too and "wear and tear"?
Jun 23, 2020 at 4:55 PM Post #3 of 5
Well, with well-designed equipment (and assuming you are not exceeding the power handling capabilities of the transducer) nothing should happen. I am assuming nothing is playing and the amp is only powered on.
Jun 23, 2020 at 5:08 PM Post #4 of 5
I had an amp (burson) which didn't like insertion of SE plug while it was on. It was triggering some kind of protection and clicking noise.
Jun 23, 2020 at 5:15 PM Post #5 of 5
So that wasn't working as it was supposed. When you have some of those amps you have to be careful when you insert anything into them.
