dguitarnut
- Dec 14, 2013
I have assembled a decent system and looking to make cable upgrades.
Thanks
Larry
Thanks
Larry
Thanks
Larry
This question is difficult to answer without some specific information about what is in your system. What kind of amp/DAC, headphones, speakers etc, are you using? What kinds of interconnects are you using now? In my own system I found that using balanced XLR cable to my Airmotiv 4 speakers rather than RCA connectors made (to me, anyway) a very noticeable difference in sound quality. On the other hand, my inexpensive Audioquest Forrest USB cable from my MacBook to my Wadia 121 amp/DAC was just as good as the considerably more expensive Nordost blue heaven USB. Honestly, I could not reliably differentiate between them. Well made cables with reasonable shielding are usually every bit as good as extremely expensive cables to most listeners. I'm sure if you provide more specific information, others will chime in.
^^^ The OP's info is in his profile.
Using balanced cables doubles the voltage and being louder affects how one perceives sound. One would have to compare with matched volume and do so quickly to really tell if there is any difference. Then there's always the human aspect.
I'm a cable skeptic too, though in this case the difference really seemed significant. I've done some very limited research on balanced vs RCA and I recall reading about the volume differences so you are likely correct.
I was considering some sub $200 silver interconnects as a starter.
I would never put that amount of money into any kind of cable.
You don't need to go fancy (or expensive) to get the highest sound quality, as long as you have the right cables. For speaker cables the gauge is obviously very important. For long cable runs, especially with mics or guitars at the end, balanced cables are the way to go to reduce interferences.
Some headphone cables are overly thin, so again a question of the right gauge.
Switching to different materials, like silver, doesn't help. I've talked to some mastering engineers and they neither use expensive audiophile nor the cheapest cables they can find, but solid, durable, reasonably priced cables (you'd say they're cheap compared to what some audiophile cables cost).
