- Oct 31, 2008
well you do benefit from them being amped with the icon but if the amp is just for them then you could live with out it but the difference the icon really makes is the DAC in it.
if you ever want to run things off a laptop the sound on them is ususaly utter crap so u can use the icon instead which is vastly better. also if you use the line out on anything they dont have a volume control so and amp like the icon will give you volume control.
the fiio is fun and cheap and makes a good difference to the cheap stuff but for something like the 530 dont expect the E5 to help them much
sorry dont know about other amps, i didint want to be carrying some brick around so the icon suited me and ignored most other things
