BenH1984
- Oct 31, 2016
The New Bee tips fit well. THese are the ones listed a suitable for 5-7mm bore. Foams is a bit softer than comply and the coating is different. Isolation is comparable although I think the comply edges it. However, for comfort the smoother coating and the more tapered shape the New Bees win out for me. Very pleased, these will be the tips I buy now as the pros (cost, comfort) are significant with a difference in isolation only noticeable in A-B listening tests.
