Gonz
- Apr 10, 2005
You don't need a line out. Most people prefer using a line out signal though.
I have to ask, and advise you here. How is the sound without an amp?
Cell phone MFRs would likely not place much value on SQ
An amp will not make a bad device sound much, if any, better.
Amplifiers take the signal from the source (which is often not powerful enough) and boost it so you can drive the headphones. If the signal being amplified to begin with, is an ugly one, the amp won't fix it. And also, the same goes for the headphones you're using (you didn't mention which)... if the headphones are cheap, like iBuds or buck store variety... you'll have no love there either.
Good power > good source > good cable > good amp > good headphones.
Any of those things being "not so good" will effect the end result.
Hopefully this will help you avoid some disappointment. By all means, do try an amp! If it turns out not so great, you'll just be that much further ahead. Next step would then be to buy an expandable memory, flash based MP3 player that can use your existing amp, phones, and SD card.
Originally Posted by tman1 /img/forum/go_quote.gif Do you need a line out to get the benefits of this amp (Xin Supermicro IV), or can I use it out of the headphone jack to get much better sound out of my MP3-capable phone (Sanyo MM-9000)? |
so it would be great if I could get great sound quality out of it (and it would allow me to hold off on a dedicated MP3 player). |
