Nickelodeon
Quote:The CM700BW are on their way to me.
OK so... when the cable eventually breaks then... do you have some advice on where or how I can replace it? Perhaps I could tear apart a different earphone with a teriffic cable, or send it to one of those companies that will upgrade to a silver cable.
Yes, something like that.
Because i've never found a great repairman, the connection between the replaced plug and the replaced cable always wears out after a while... but there never was any problem with connection between the replaced cable and earbuds.
Hi penartur:
Does the photo that I've posted below (which I have culled from a thread started by you titled "Where to buy "tips" for Audio-Technica CM700?") show the handiwork of the CM700 recabling effort performed by the technician that work on your phones?
