kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
- Jun 21, 2001
quote
What is considered the ultimate dielectric for a capacitor ?
There is only one real answer. A pure vacuum glass cap.
Nothing else comes close, not even teflon.
I use teflon boards for some of the very high frequency
work i do.
teflon is non hygroscopic. That means it will not retain or
attract water. Also because of the way it is made, the thickness
can be very accurately controlled. For microwave striplines
this is of supreme importance.
Just about every epoxy based circuit board out there attracts
and retains water. The board capacitance can therefore change
due to humidity and temperature.
For audio use, (like the d/a board inside a theta gen V) teflon
it is a disaster. Unless secured to a very flat surface it bends
and rolls up, twisting and turning with the heat. For an RF
board with 20 screws holding a 2 x 3 inch board to a piece
of brass, great.
The cyanate ester that levinson uses is among the best
material available. Expensive however.
work i do.
of brass, great.
