ruZZ.il
- Mar 26, 2007
yeah, Tangent has done an outstanding job, I, and I'm sure many many other people, really appreciate it (Thanks Mr. Young!). which means you basically have to read through the the PIMETA pages a bit then focus on the parts list and the parts selection.. you should print out a checklist and make comments for yourself while you're doing it all, like, who you ordered from, what value you ordered, etc. What I did was open 1 tab with the parts list, another tab with the selection guide and for every part I just read what flexibility I had and worked from there.. then I had another 2 tabs, digikey and mouser.. plus the few bits from tangents shop. you'll need to look at the schematics and s.guide thoroughly for the resistors.. mouser had all the ones I needed. In retrospect, I'd have ordered slightly different values for some, like gain, but I'll tweak it soon enough.. and I've learnt!
I suggest doing something similar.. cant go too wrong.. also, I suggest socket mounting all your stuff so you can play around in the future! the opamps may need little mounting boards depending what you get.. you can get them at tangents. the build guide is really put together well too, and when you're done, you'll find plenty info around here for adding a charging circuit (thanks tomb!) which I found useful. (maybe you should find it first and order the parts.. you'll want it later, anyway.. they're pretty standard, I picked up similar parts at some local electronics bits shack here)
I found the STEPS to be a nice build too. I built mine for my future projects and its busy charging my pimeta right now
enjoy!
enjoy!
