hidehide
- Apr 27, 2016
Thank you. That will be my last resort when the shell broke up completely... I will keep it as is right now since there are no effect on sound quality, just cosmetics..
Any recommendation for a decent balanced cable for the W60 (I have the ES60) with recessed mmcx connector used in Westones. I want to spend in the $150 range. I really don't feel like spending $200 for cable like the Silver Dragon or the ultra thing Westone cable. Thx.
Dude, is the ES60 considerably warmer than the W60? If it is, that may be the thing that I want (an IEM that is similar to the older Westone flagship custom, ES5). Your advice would be very very very helpful. Thanks man in advance for your thoughts.
Yes I've used the same source in store. And same songs.
and here is the picture of faceplate. And it writes under the faceplate w60 and write w60 on faceplate so I'm sure faceplates are for this product.
I've left it for burn in. Hope it helps on soundstage.
I got some warranty replacement W60 today.
I think they have been sat on a shelf for a while, as they have the old faceplates and loose and slightly wobbly cable connectors, but I swapped the cable with the one from my UM Pro 50 and the connection is nice and solid now, and I've ordered a new cable for the UM Pro 50.
I really like the UM Pro 50, and I'll keep them as a backup, but the W60 is something else.
I've raved about how good the W60 sound before, but having them back has been like a revelation all over again. They sound even better than I remember.
[COLOR=111111]you compared them with other models? for example, the um pro50.[/COLOR]
[COLOR=111111]I now seriously think about buying this model, your post does not give a positive reputation with this model![/COLOR]
Sorry gosod. I didn't mean they are bad. They sound really nice. I like the sound but build quality is a shame. Not at this price for example i had a lot of 100 $ IEMs but build quality was really better than this one. But if you are considering to use them everyday on the go you must have easy access to guarantee because they are fragile. They really tried to get best possible sound of it and they have succeeded in a lot of ways.
Covering up the gap left by the faceplates with Suguru would probably solve the cracking issues for good and is also removable if Westone ever releases "good" faceplates.
https://www.amazon.com/Sugru-Moldable-Glue-Classic-Multi-Color/dp/B008URBC9I/ref=sr_1_1?ie=UTF8&qid=1469938498&sr=8-1&keywords=sugru
