DaveRedRef-III
I think battery power is about due a 50year heyday Rob. R&D investment in that space has been exponential in recent years. The spinoffs will hopefully feed into portable devices.
Next year SAMSUNG and TSMC will start producing in 7nm and in two years they will reach 5-3 nm. But what about FPGA they can't do it with SAM or TSMC ?For sure - but - Moore's law is running out of steam. Moreover, it is becoming more and more expensive - a 13nm mask set will set you back $150M - that's a sizeable percentage of an FPGA's companies entire annual revenue. Also, the economic sweet spot is two nodes below state of the art - so currently the most economic point is 28nm process. My guess is 7nm will provide FPGA's allowing an economic portable M scaler; but that would need state of the art to be at about 2 or 3 nm for 7nm to be economic - and we are many years away from that - perhaps decades. The key issue for portability is power - and we need at least a tenfold improvement in power dissipation.
Regarding FPGA limits ...my understanding from HQPlayer's designer is that modern cpu's can trivially do many millions of taps.
A 16 nm FPGA from Xilinx today costs thousands of USD - and the availability is rocking horse pooh... Also, test wafers will be available at 7nm, but it will be with poor yields, with the process not qualified or calibrated, and then the tools will need updating and qualifying, which will take a year or so. Then the designs can start, and a successful design will be production ready in a couple of years after that. So you are looking at 3 years before parts become available, and even at that point yields will be poor.Next year SAMSUNG and TSMC will start producing in 7nm and in two years they will reach 5-3 nm. But what about FPGA they can't do it with SAM or TSMC ?
I am very glad you are addressing this issue as well. We are talking here all the time about perfect reconstructing the impulse and transients, assuming that the ADC conversion was perfect. But what if it wasn't? There are several recordings which drove me mad with the pumping noise going up and down. I couldn't understand it, since when played through different DACs and devices, the noise stayed more or less constant. I guess the noise sneaked in there already during the ADC process.Absolutely, mic choice and positioning are crucial. But there are vast problems that current ADC's have, for which Davina will be able to solve. I will be doing a post soon about these issues.
The secret sauce is the WTA filter so until HQ player can build a filter that sounds as good as WTA which Rob took 30 years to refine, I wouldn’t pay too much attention to multiple millions of taps claims.
Ho hum.
We’re lucky enough to get a million WTA taps in 2017
Yes - a single DX input and it will turn the unused channel into a negative channel; so you can bridge, or bi-amp (and swap the OP connection on the inverted channel).Rob, are you planning to have a Dual Monoblock option in the planned new style amp releases? I just want to swap to mono block dual amp setup as soon as possible.
