analogmusic
- Apr 15, 2015
I have to say congratulations on achieving your dream of one million taps in 2016
I thought this was 5 to 10 years away...?
I have already looked into that, and its possible that eliminating the ADC won't actually make a great deal of difference. The majority of the BOM cost is metalwork, FPGA, PCB and power supply. The ADC savings (analogue integrators and pulse array) is actually quite small and would probably be outweighed by the costs of producing two products.
I want as many people as possible to enjoy the benefits of M scaler tech, so we are trying our best to reduce costs.
Rob
Reading all this about "M-scaler" and the BluMk2 could someone explain to me or point me towards an explanation by Rob about this M-scaler and what it does? Thanks!
Have you read the previous page?
I did, but I kind of malfunctioned the first time. Just read through it again. So the M-Scaler basically means a WTA filter employed in a different way with 1M taps in contrary to the normal WTA filters used in the Mojo and Hugo which have a lower value taps?
There are many ways to think about digital filtering and taps. All are legitimate. But this is how I think about it. Most DACs need to upsample from 16/44 to 24/704 prior to playback. Imagine the original analog waveform during recording, the 16/44 are quantized signals from that recording. Most DACs cheat with short tap length filters. When they actually use their non-apodising filter or apodising filter to upsample to 24/704, because it's an approximation, they're a bit off from the original analog waveform. The frequency response/spectrum within the audible range is the same as the analog waveform. You would think that if the frequency response and spectrum are identical, it wouldn't matter. But according to Rob Watts, there is an audible difference because the waveforms are not identical. There are two ways to better reconstruct the original analog waveform in 24/704. One is to use a better digital filter like WTA so that with the same tap length, the upsampled waveform can converge on the original analog waveform better than other digital filters. Another way is to use longer tap length so that there is more calculations done so that the 24/704 waveform becomes closer and closer to the original analog waveforms.
So yes, the simple answer is Blu has longer tap length than DAVE which has longer tap length than Hugo/Mojo.
There are several consequences to WTA and longer tap length. Because the 24/704 is closer to the original analog waveform, you end up with much lower higher frequency noise because you can imagine when we say the poorer upsampling being further off from the analog waveforms, the difference is very small and when you translate that into the frequency domain, you're essentially getting less antialiasing artifacts and less high frequency noise.
Another consequence that I still don't fully understand is that transient timing and timbral accuracy improves with longer tap length. It's just what Watts and many DAVE owners hear. Watts calls this improved timing accuracy. I still struggle conceptually why this happens. I can imagine the amplitude of the analog waveform from longer tap length being more accurate except our ears don't hear amplitude, we hear frequencies. So why better timing? Not sure.
