LaughMoreDaily
Can someone post a small review vs. other players they own? I'll do it when I get mine vs: the Sansa Clip+, and the Benjie S5. The Sansa Clip+ was the most expensive one.
Hello. Does anyone know what the output impedance of Walnut v2 is? Is it greater than 1 ohm?
Plus maybe you want to hear from someone who doesn't think their Walnut is the greatest thing since sliced iPods.
I'm a bit afraid to recommend to friends to buy it now though, because of people having issues from late orders like the wonky output and corrupted sd card. Might be better to wait till the hype wave cool off or Im overreacting? lol
I think I am unlucky as I am one of the 150 buyers surge of orders, got a jack input problem, it can't grip tight on some 3.5mm jacks, some others are OK. I took out the PC board the soldering looks good. Lucky my fav monk+, qian39 , SHE3800 and TY Hi 32 are tightly fit, hard shake them jacks, no problem. Others plug in, slight touch of the wire near the 3.5mm jack the sound run. Could it be the quality of the female 3.5mm input jack? I have to use the short extention wire from my HD681Evo to play the other earbuds since the wire jack is tightly fit.
His gifted SD card is corrupted as well cannot use it after new partition and format. After playing a few newly loaded songs the walnut freeze
I told CKLewi about my problems awaiting his answer. Anyone got the same problem on the walnut?
Yup, it's high, you can run it into another (less powerful of course) amp if the output resistance is important to you. However this only applies to BA & more imporantly hybrid BA IEM users, and even though I'm not much a fan of IEMs I find BA to be unsuitable. But that is the only situation you have where an output resistance high as the Walnut's could have a measurable negative impact on sound. This lil guy can make the most power hungry headphones shake nice n' good.
We have to understand this guy does it as a hobby and has a normal day job
Hopefully he'll be able to grow his reputation through this and move on to develop more stuff, increase the quality even further and make some money from it, because he clearly has a talent for this. I know I'm interested in what's next, and whatever that is, I'm in!
Yep. It is not ideal for BA iem.
