delladood
- Oct 2, 2011
holy in ear monitor batman! the AKG 3003 costs over 1000.00USD! LOL what!?
Regarding size, though, I think the GR07's dynamic driver is a bit on the large side, so that might change the size compared to the K3003s. Anyone know how big their dynamic is?
Quote:Regarding size, though, I think the GR07's dynamic driver is a bit on the large side, so that might change the size compared to the K3003s. Anyone know how big their dynamic is?
on the gr07's its 11mm. Im assuming if its dual BA and 1 dynamic the dynamic will be 7mm as always.
But see then you don't get the advantage of the GR07's epic driver!
Quote:But see then you don't get the advantage of the GR07's epic driver!
I really enjoy the gr07's! I find them to be so perfectly balanced with such a great sound stage and above par isolation. I really dont think you can beat the gr07's for price and balanced sound. I really want to get an amp with the 07's.
Mostly I meant it would be nice to combine the performance of the GR07 driver with the extra range of the dual armatures... So basically combine the GR07 and GR01. (Whoever did the math in the last page got it pretty spot-on, I think)
Hmm.. If the K3003's dual BAs are in the nozzles of the IEM itself.. Maybe Vsonic could still retain the big 11mm dynamic in the GR07, and perhaps modify the nozzle a bit to fit dual BAs in them.
Wait, are they? doesn't that impede air coming off the dynamic? Either way, I can't wait for these to be unveiled... Much more interesting than 6 armatures IMO.
Quote:Wait, are they? doesn't that impede air coming off the dynamic? Either way, I can't wait for these to be unveiled... Much more interesting than 6 armatures IMO.
Yes they are.
Technically you could say it's not "in" the nozzle.. But it is in the "tube" in front of the dynamic driver.
AudioFly's (forthcoming) AF78 hybrid driver IEM (dynamic driver+-dual BAs) houses the BAs in the nozzle and the dynamic driver in the housing.. so it's definitely possible/likely.
Isn't that just one BA one dynamic though?
Upon further inspection.. you're correct... so it remains to be seen if dual BAs can be fit into a nozzle.
