But if you're used to the way most music sounds through the M-100, and you produce music -- using your M-100s -- to have a similar frequency response that most other music has through your M-100s, then the production result should be OK, shouldn't it?
ALRIGHT, I'VE HAD ENOUGH!!! You always advertise your EQ 20 times a forum in the fasion of a 70s commercial, as if it's the only thing you have to do. And now you're saying that if someone were to use your EQ presets, where you almost only hear the lowest notes, listened to it every day of their life, then decided to make music, it wouldn't turn out horrible? I am in a group chat, where we have a running joke about your 9034i38+ custom Rockbox EQ presets. YOU'RE A JOKE!
Ehh, the preset ads are only slightly annoying, though cmon, m8. Your logic is a bit bs XD
Now, for my explanation on why you shouldn't use the M100s for mixing and mastering. The only thing it's good for is to be a portable beater can. If you're a basshead and you need something portable, and you like how this looks, that's when you should get it. It's kind of fun sounding. The problem with it, is the sounds that come through the cable aren't the sound that come out. Bass has low distortion, but that doesn't mean the bass is the same. It doesn't have enough bass detail to be able to replicate all of the little things that make people love planars and such. They don't monitor, they just let you There are quite a few things around the $100 price point that will definitely beat the M100's mids. It's just not very good. The treble isn't special either. Soundwise, the only thing special about this can, is pretty good at the price point for how much it's emphasized. It's like a better Beats headphone (Solo 2 beats it, but it's closer to neutral, so the drivers won't go out of control from excess bass).
And about how you adjust to different responses, I can see where your reasoning comes from, but lemme shine some light on why that's false.
One, dips and peaks are difficult to account for. You're gonna end up screwing up the tonal balance if there's a bunch of sibilance that you can't hear, because your headphones put a dip there to make it an easier listen. Likewise, there could be a peak somewhere in the mids, it could sound weird to you, so you take it out. Turns out, you didn't want that to be gone, because now people are going to think the mix sounds thin.
Two, in the case of DPJ's custom rockbox preset EQs, you'd pretty much only hear the lower bass with a very tiny amount of treble and mids in there. If you were him, and you decided to make music with said preset, you'd end up having no bass in the mix, and a large amount of treble and mids in the mix. "How could this be?" you wonder, "If I'm only used to low bass, why shouldn't my mix turn out with only what I'm used to?" Well, DiscoProJoe, let me answer your question. A 23 db boost of bass at 31 hertz doesn't boost every sound at 31 hertz by 23 decibels. It's more like multiplying the frequencies than adding them. A quiet bass sound isn't boosted nearly as much as a loud bass sound. Likewise, if the treble is lowered by 10 hertz, quieter treble will get slightly quieter, while loud treble will get a lot more quiet. Now, this isn't nearly as bad with an M100 as a ou will miss the odd tonal balance. If this doesn't make sense, just think about it for a bit.
Finally, the M100 is crap compared to the HD600. The HD600 is neutral. It doesn't mean that a neutral headphone will always be technically superior, but people don't design bass heavy headphones to be technically amazing. They make them to be enjoyable to the bass heavy crowd. Val didn't make the M100 to be detailed, he made them to be durable and fun to his desired crowd.
Now, for a recommendation, JiDey, neither of those are the detailed in the price. If you're willing to go the HD650 territory, you can find a cheaper Beyer DT880 that is super detailed, but it'll have an (I think) middle to upper treble peak that lots of people don't like. It's slightly bright, but it's a great detail whore. The HD600 is still my recommendation if you're wanting something that will reliably show you what you need to hear. It's less detailed than the K/Q701 or Beyer DT880, but it's one can that people with HD800s still reach for when they want the tonal balance.
Does anyone have any objections to what I've said?
