DrSheep
- Nov 17, 2012
There is no hard fact, but most people, including myself, think it uses the ES9023.
There's some space underneath the XL pads but there isn't as much play. Then again, you shouldn't need the mod with the XL pads.
If the twisted paper towel mod isn't sufficient then I recommend trying the rope trick version. Quarter-inch nylon rope is more resistant to crushing. Cut to 1.5-2" lengths, bond the ends with a little heat to keep them from fraying, and stuff under the upper and lower angles of the pads.
I have no idea about the lead times on the black pads.
Speaking of mods, the XL pads do have a little boominess about them (kudos to Val and V-Moda for keeping it to a minimum) so I've been experimenting with covering the bass ports to rein that in. Completely sealing them with electrical tape works too well (imagine that). I'm currently trying paper medical tape. One layer seems good for my industrial and EBM, two layers seem better for rock and metal.
I just remembered a way to get red pads to match the Shadow trim: sock mod.
How about covering only one or two of the bass ports with electric tape? I guess I should try it on my M-100 with XL pads...
Or maybe V-Moda will come up with some kind of active lighting system.
Sock mod is off for now. There's not enough rim around the cups for socks to hold onto. They just slide off.
Thanks for the tips. It's cool that the shields can be used to make this simple mod invisible, and it does not require opening up the earpieces or any internal change, either.
Can you try? We don't have the time for the lighting system as we are busy making all the new products BUT we want to see some mods. If it works, we'll sell it on our site somehow!!!
QUICK QUESTION - what side do you plug cable into? A future model has a strange feature so I need to know...
I am planning on buying the V-Moda M-100s, as I want headphones that I can use for all of my audio needs. That means that I will also be using them for PC gaming. Can anyone recommend to me the best sound card for these specific headphones? One that will provide great sound for music, as well as allow for positional audio. Thats all I need to know, thanks in advance!
