DigitalFreak
镇老鹰
- Jan 1, 2011
So get a VOIP adapter and problem solved????
Can't believe I missed the XL pads debut. Boy, those definitely remind me of the Mad/Alpha Dogs. Just curious, though, if they're gonna be compatible with the LP.
And on a separate note, it seems my Apple remote cable is close to giving the ghost, as jiggling is starting to create interference. Now, audio-only cable that came with the LP is too long for me to use outside, and I don't need the remote, as my iPod is now Rockboxed, so if anyone could recommend audio-only cables with better microphonics and/or are relatively cheap (~$30 max), I would greatly appreciate it.
Per Laborem ad Astra,
JbstormburstADV
JbstormburstADV
Why not just get the new CoilPro cable for that price?
Ooh, fancy that. Inexpensive 3.5 mm cables that are flat.
http://www.ebay.com/itm/3-5mm-Male-M-M-Stereo-Audio-Auxiliary-AUX-Cable-for-PC-iPod-MP3-CAR-Flat-Noodle/370828388956?_trksid=p1.m2292&_trkparms=aid%3D333005%26algo%3DRIC.FIT%26ao%3D1%26asc%3D161%26meid%3D228634810483056151%26pid%3D100075%26prg%3D1087%26rk%3D1%26rkt%3D6%26sd%3D151075503635%26%26clkid%3D228658764190172193&_qi=RTM1327406
The purple one looks mighty attractive to me.
I believe this is the post you are referencing to, but there is no mention of anything related to microphonics, which is a valid concern since we are in this price range.
UPDATE FOR A NEW "LIL PRODUCT" IN ONE WORD...
"TUONO"
http://v-moda.com/tuono-lightning-cable/
Tuono translates to "Thunder"
