H T T
- May 11, 2013
Momentum on-ear has a more detailed sound than the M80, but has a strong upper mids peak and poorer treble clarity than M80's. Bass rocks harder than M80's. DT1350 kills the other two. If you can go for DT1350, I definitely recommend trying it first. If you are unhappy with its fit and sound for whatever reason(s), then try the Momentum on-ear.
I find the MOE to have much better treble clarity than the M80. Try a tune with piano featured. The M80 fails. The MOE does wonderfully. I still highly recommend the M80 for pop. Amazon USA has the 1350 for under $200. That is worth checking out. I have settled on the MOE (I bought for $90) plus M80 (I bought for $80) plus Mikros 90-the best on-ear for classical/acoustic/jazz music, beware the clamp. (I bought it for $60). All the bases covered at a very high level.
