mmerrill99
Member of the Trade: M2 Tech
- Mar 2, 2006
10KHz jitter figures are almost useless - it's down at 10Hz and below that the real performers stand out - not a spec that most datasheets show & the Crystek clock I will use is no different but read on.
Here's the Crystek link to their clocks Crystek Crystals, PECL, SMD VCXO, Clock Oscillators The particular one I'm talking about is the C33XX range. BTW, look at the ppm for these clocks - they start at 20ppm and go up but as I said this is not that important.
Jocko at DiyhiFi did some tests which showed the phase noise at 2Hz for 3 different clocks:
DIYHiFi.org • View topic - "Clocko Jocko" which is where I got my figure of -100dBc @ 10Hz for this Crystek clock (you won't find this on the clock datasheet). Comparatively, he compared it against a well known audiophile low jitter clock which showed about -90dBc @ 10Hz.
The comparative figures change a bit when you look at jitter @1Hz (this is almost never given in datasheets) - Crystek clock -51dB, "Audiophile" clock -65dB
Hope this helps
Hope this helps
