Share2Care
- Jan 15, 2017
Hey Ladies & Gents.
I am thoroughly enjoying my Schiit Jotunheim and I am utilising the DAC module fully with my PC.
With using my PC and a USB A B cable, I know of several devices such as the AQ Jitterbug, iFi Purifier 3.0, iFi Defender and even Schiits own WYRD!
IF I were to connect a AQ Jitterbug to the USB cable connecting my Jot to my PC could I expect a somewhat tidier / cleaner sound to be available?
These plug-in adapters are around £40 each whereas the WYRD being £110.00.
The questions I have is has anyone had a play around with these USB adapters or has a WYRD? If so, what are your thoughts?
Ultimately, I believe in Schiit and do not believe they would make something unless there was a benefit to be found. A rare thing is trust in an audio manufacturer!
So, using a Jotunheim, will I notice a difference and if so, is it worth £100 device or the cheaper and more flexible options in terms of being able to use with your laptop etc.
I am happy to spend the money if it warrants it so YOUR advice, knowledge, guidance and help would be really appreciated.
Thank you
Thank you
