guzzler
- Jan 17, 2003
Have you measured all the voltages in the circuit, you should get almost exactly 5V and 3.3V from each the regulators. The voltage out from the MAX1722 should be pretty much 5.5V. Check connections from the PCM2702, and also the coupling capacitors.
g
g
