marone
- Apr 6, 2013
I highly recommend getting a large UPS backup with surge protection.
Mine 650 VA 360 watts.
Surge Protection is just an isolation transformer plugged to the mains.
Backup is a Lithium battery that lasts a few hours for laptop etc.
The main improvement seems to be the isolation transformer.
Running the DAC & headfi amp off the battery alone doesn't add much but the surge protected outlets (running off transformer secondary) do.
Big increase in bass slam and clarity, drop in "electronic hash", and speaker amplifier runs much cooler.
This could be due to mains being cleaned of noise and the heavy lifting is done by the UPS leaving the amp ps with less work and thus less radiated heat.
An $80 80 EUR upgrade that makes your system sound more 'audiophile'.
Plugging speaker amplifier into mains the drop in SQ is immediate.
Playing DAC & headfi ampfi alone into headphones also sounds great when plugged into UPS with speaker amp off. Noticeable SQ improvement.
Current speaker amp is only 15 watts so this might not work with your 1000watt monoblocks.
Definitely will work with any DAC headfi amp combo.
It just sounds much better.
