[UPDATED] Best power conditioner around. [Furutech FLUX-50 NCF Gold]
Aug 7, 2022 at 3:46 PM Thread Starter Post #1 of 77
OCC7N
I was thinking of upgrading the power before the individual power supply to LPS for my system.
1. Computer/Streamer STreacom has its own built in psu.
2. GamerPC
3. Display
4. iFi Diablo
5. JCAT USB PCIE XE will buy LPS for it.
6. Chord TT2 using standar psu
7. Headphone amp, not jet bought the amp
Isn´t it a good idea to start with mains before the individual psu of the devices?
Couple of other questions
Will I be able to connect gamerpc(400 watts) to a power conditioner?
How about power connectors with only two pins. Will they benefit without the earth pin?
Aug 7, 2022 at 7:48 PM Post #2 of 77
2. GamerPC
3. Display
4. iFi Diablo
Lots of choices in that price bracket. Maybe the Audioquest Niagara 1200?
Thats what I would get, if I didn't have a power conditioner already.
Aug 8, 2022 at 2:34 AM Post #3 of 77
Thats the one I always get when I search in google/youtube…but
Then I hear/read that people sell em after some time and realise the soul is back in the sound.
So something tells me I should buy a surgeprotector and better psu for the devices
Aug 8, 2022 at 3:46 AM Post #4 of 77
Aug 8, 2022 at 9:00 AM Post #5 of 77
Aug 8, 2022 at 9:03 AM Post #6 of 77
The things I actually emphasize on is ground issues and surge protection. DC blocking is in somewhere between this two things I guess.
I dont want something that “EQ” the sound. Just lower noise from the mains
Aug 8, 2022 at 9:14 AM Post #7 of 77
I see, in that case you could do what I did.
I have a furutech etp80 and an ifi supanova as the power cable for it, the ifi cable has built in surge protection and the furutech plc is very basic and doesn't do heavy filtering.
For some extra noise reduction you could try using sendust or copper tape on the breaker box.
Aug 8, 2022 at 9:19 AM Post #8 of 77
Ok that sounds interesting. Noted🙌 Thanks
Aug 8, 2022 at 9:24 AM Post #9 of 77
Aug 8, 2022 at 9:28 AM Post #10 of 77
Aug 9, 2022 at 8:36 AM Post #11 of 77
That's true, yes. Our SupaNova also measures incoming noise and injects its opposite wave to invoke the cancellation effect, so in that sense it's an active cable. Hope this helps, thanks!
Aug 10, 2022 at 3:41 AM Post #12 of 77
Try looking at Puritan Audio PSM136.
Aug 10, 2022 at 6:01 AM Post #14 of 77
Im abit hesitant of buying these purifiers in general. I dont hope they smooth things out too much. Its not every dac/amp that needs it I think. So I am looking for something that does not do too much…
Example. The ifi purifier3 I used for RME DAC FS, because I find the sound very harsh. It literally makes that dac better after experimentation….
Does my TT2 needs it, didnt even bother because it sound real good not harsh but defined.
So I am abit hesitant. Stories about people selling there conditioners, and experiencing better results.
Aug 10, 2022 at 6:18 AM Post #15 of 77
It's all relative. Some folks appreciate extra smoothness and cleaner background conditioners usually provide, but others like the bite they get without such power components in their setups. To try one and find out for yourself whether they work for you or not is the best way to move forward. But if you like what our iPurifier does, the odds are that you'll be happy about similar gains elsewhere :wink:
