Cassadian
- Jan 29, 2012
Disappointing but highly understandable. In my opinion that designer was smart. There's no way you could tell the nuances of sound while out and about. This system seems to be transportable rather than portable so if you sat down at a cafe with your laptop it would still be easily packed and taken out for high fidelity sound.
Kudos to UM
That won't work because the active crossover is specifically designed for the 6 driver earphone in the PP6 set.
The main designer's idea is to give you a good system to use at home, and when you are out, you can just use the earphone to listen straight from your phone or MP3 player.
I guess our main designer doesn't like the idea of carrying an amp while walking on the streets.
Kudos to UM
