I have a pair of PL2500 ordered and on the way. I'm curious to compare them, sound and construction wise to the PL650.
They look, from pictures, like they're constructed from the same plastic mold, with the exception that the 2500's are open and the 650's closed. This appeared to be accomplished by a sonically welded plastic ring covering the vent holes on the inside of the 650 and a cosmetic plastic film on the outside covering the same vent holes.
The drivers differ as well. The 650 uses the 40mm gold sputtered mylar and the 2500, the 40mm titanium sputtered mylar. The voice coil is 75 ohms on the 650s and the VC on the 2500's is 40 ohms. This should be interesting.
Many of you are familiar with Sony's famous MDR-7506/MDR-V6 headphones. They use a mylar diaphragm driver. For a year or two, they produced an MDR-V7 model which was more expensive than the V6. The primary difference was that the V7 used a gold sputtered mylar diaphragm, otherwise identical to the drivers used in the V6/7506. They sounded a little brighter, but cleaner, as I recall.
I would expect that gold sputtering, would help suppress modal resonances on the diaphragm, if it had any effect at all, but not make it quicker. The actual mass of the gold is probably less than that of the air being moved, so maybe it made no practical difference in the mass of the diaphragm.
I would expect titanium to be resonant just like a titanium bicycle. So intuitively, the drivers would be expected to sound more ringy/worse than the gold sputtered ones. But, who knows... Maybe the titanium sputtering is actually effective in stiffening the diaphragm, making it a better piston.
Are there any mechanical engineers out there who could lend some intelligence to this wild speculation?
