wizia
- Jan 29, 2008
What's the general consensus when choosing between 900 and 2900?
The pro900 change quite a bit with burn-in. They never become quite as smooth and tight as the pro2900, but I think you should give them time, before drawing any conclusions.
Leander7777: Do you still have the 900s? These cups seem a lot smaller on the 2900s, or is it just the pads?? Either way, I'm having none of the loose positioning issues that I had with the Pro 900s, which always drove me nuts searching for that sweet spot. Just another positive in the 2900s arsenal. So far the only thing 'better' with the 900s is the bass impact, which I suppose is to be expected with their closed design. Even so, my basshead gf still likes these quite a bit more as well. Still burning in, more impressions down the line...
-Daniel
I too am glad for the 2900/900 comparison. I am a happy owner of a pro 900 and at the moment looking for an open back to compliment it. It seems the 2900 should fit the bill. I was actually looking at the HD650 as well. Being as that I haven't heard either of the two, what would be a better all around headphone, hd650 or 2900? I listen to all kinds of music so any suggestions would be great, thanks.
-Daniel
I think that is the biggest downside to the Pro 900s for me, finding that sweet spot. It takes a good 30 seconds when I first put them on to get it right, and then I adjust them often. I just want a headphone I can put on and forget about. Maybe the D2000 will satisfy that need.
These are my impressions as well. Most people consider the Pro 2900 just an 'open' Pro 900-but I feel they are are different enough to own each if one wanted to do so. The more my 2900s are burning in, it seems to be quite a great all-arounder, whereas the 900 seemed very limited to just couple of genres. I relied on the 900s primarily as my movie/gaming cans, and very little for music since I don't really listen to EDM. I am enjoying the 2900s a great deal more, and the only area they are behind in is bass impact-but then again I'm not running them out of an amp atm. Long story short-the 2900 really aren't that similar to the Pro 900s as one might expect. They seem much more refined, neutral, and natural sounding. The Pro 900s are definitely more aggressive, sibilant (ugh), and not as refined in comparison, but certainly better for electronica, and worse for everything else. Not that the 2900 aren't good for electronica by any means...I should just wait til I get them hooked up to an appropriate amp before saying more lol. My still early .02
-Daniel
